Varning: Magnetic oil drain plug from ebay
Post by Killerwhale » Wed Oct 31, 2007 10:48 am
Was changing oil this weekend and got sweaty.
The magnetic oil drain screw bought from evilbay just shredded the threads out of the engine.
LUCKILY i had the standard much longer one here so i could use that....but beware. It´s CRAP!!
Post by youngy » Wed Oct 31, 2007 11:00 am
bad workman, tools etc etc
Post by Killerwhale » Wed Oct 31, 2007 11:04 am
martin young wrote:bad workman, tools etc etc
What are you speculating in here?
I was nowhere near the Nm on the moment wrench.
Post by phuk72 » Wed Oct 31, 2007 9:18 pm
Hold the front page.
Man buys crap product from ebay :roll:
kenmore
Evil Bay/Magnetic Drain Plug
Post by kenmore » Wed Nov 14, 2007 11:11 am
Thanks for the heads-up. Was thinking that they were a good idea.I,ll keep my hard earned for something else.
Thats the good thing about this sight, we can all save each other a lot of time and money so then we can do the important thing and ride our trixies.
function=form
Re: Evil Bay/Magnetic Drain Plug
Post by Killerwhale » Wed Nov 14, 2007 11:47 am
kenmore wrote:Thanks for the heads-up. Was thinking that they were a good idea.I,ll keep my hard earned for something else.
Glad to help, even if some guy´s in here are just fekked sometimes
HolerTogni
Post by HolerTogni » Wed Nov 14, 2007 11:35 pm
Hi (thread) Killer! :wink:
Killerwhale wrote:...
I bought some off Louis and when tightening I found that quit a bit before reaching the recommended torque my feeling said "STOP!"
Since at every oil change there's a little swarf on the magnet I keep the magnetic screw and just tighten it not with the recommended torque but enough to keep it from dripping and from damaging the thread.
Feeling greetins from Munich!
TRX 850 & Racetrack-TRiXie
Post by Quan-Time » Mon Dec 03, 2007 3:19 am
if you have access to a lathe, you can buy a magnet, drill a hole in the plug, push the magnet in and loctite it into place.
As for torque settings on a oil drain plug, ive NEVER used it.. always done the feel method.. Never leaks, never strips..
But i wouldnt argue the fact its NOT the best way of doing it.. but it works for me.
Biffidus
Post by Biffidus » Mon Dec 03, 2007 3:57 am
Also, with a shorter threaded section you shouldn't be using as much pressure!
Trixz
Post by Trixz » Mon Dec 03, 2007 9:43 pm
I use the recommended Nm for a lot of bolts, but for the oilplug, just a wrench and my 'just tight is tight enough' works fine :D
In 2 weeks time, the oil change is about to happen again so.... 8)
Janitor
Post by Max » Tue Dec 04, 2007 12:08 am
I buddy of mine trashed his engine with one of those little gems. Autopsy revealed a bunch of ground up parts and... no magnet. It came off and attached itself to something moving.
Post by Quan-Time » Tue Dec 04, 2007 2:14 am
OUCH... thats ... not good.
how the hell does that happen ? must have been made out of putty or some crap.
Janitor
Post by Max » Tue Dec 04, 2007 4:31 am
More like the goo holding it in let go methinks...
