Emulsion tubes
bane
Emulsion tubes
Post by bane » Thu Sep 15, 2016 3:18 am
Does anyone here know if the partshark/partzilla 93 tdm emulsion tubes can be used with the trx?
Different part numbers 3GM-14141-92 for the trx, 3GM-14141-94 the tdm. The factory pro tubes
are listed as interchangeable with both so I'm presuming yes. I have keysters in at the moment but i
don't need a full overhaul, just tubes.
cheers,
Bane.
Re: Emulsion tubes
Post by dicky » Mon Sep 19, 2016 6:10 am
If it has a different part number then it will have some variation.
Yamaha did not renumber parts for no reason.
It may well fit, but it will be different.
Snod Blatter
Re: Emulsion tubes
Post by Snod Blatter » Mon Sep 19, 2016 10:01 pm
They are slightly different, Mk1 TDM uses Y-4 while Mk2 TDM and TRX use Y-2. I believe this is a slight variation in length between the two tubes. Whether it really makes any difference though..?
Of course Factory Pro considers the difference to be insignificant..
Re: Emulsion tubes
Post by dandywarhol » Mon Sep 19, 2016 10:39 pm
Snod Blatter wrote:They are slightly different, Mk1 TDM uses Y-4 while Mk2 TDM and TRX use Y-2. I believe this is a slight variation in length between the two tubes. Whether it really makes any difference though..?
.................and Factory Pro tubes are very good indeed - not so their needles for road use :?
