Deano
by Deano » Fri Jan 13, 2017 11:24 pm
Hello fellas,
Hoping to pick your brains on this one. My bike has been fitted with Blue Spots and what appears to be a 14mm Master Cylinder (Nissin with 14 stamped on the side).
The brake lever doesn't appear to be a standard TRX part, I'm thinking it may be from an R6. Could anyone identify it from the picture? I will try to get numbers from the body when I remember to take a lamp to the lock up. Cheers in advance, Deano.
Deano
by Deano » Sat Jan 14, 2017 3:49 pm
Cheers Cobba, I knew someone on here would know.
Bikerlad
by Bikerlad » Sun Aug 23, 2020 9:11 am
I have the same master cylinder on my TRX.
Silly question, but is it an upgrade on the original or should I look for an R6 master cylinder.
by dicky » Sun Aug 23, 2020 9:55 am
What calipers do you have?
If you have blue spots then you should also have a 14mm master cylinder.
Doesn't really matter which bike its from as long as it's 14mm.
Bikerlad
by Bikerlad » Sun Aug 23, 2020 1:48 pm
I have bluespots.
Thanks for the reply.
dicky wrote:What calipers do you have?
