Advice on carbs please.
Mikerhayward
Post by Mikerhayward » Mon Jul 18, 2022 5:18 pm
Hi guys, long time since I've been on here. I need to inspect the float needles on my trx. Can somebody advise if it's possible to remove the float bowls with the carbs in place of do they need to come off.
Thanks Mick
Rod.s
Re: Advice on carbs please.
Post by Rod.s » Fri Jul 22, 2022 7:41 am
Mikerhayward wrote:Hi guys, long time since I've been on here. I need to inspect the float needles on my trx. Can somebody advise if it's possible to remove the float bowls with the carbs in place of do they need to come off.
Thanks Mick
You'll need to remove the carbs...
Post by Tarwetijger » Fri Jul 22, 2022 8:40 am
Even if it would be possible, I'm sure you don't want to. :D
Mikerhayward
Post by Mikerhayward » Fri Jul 22, 2022 9:13 pm
Thanks,
seems a bit of a job to have to take the carbs off just to adjust the float levels. the recount to measure again. Always done it when the carbs are easily accessible.
Hey ho.
Mick
