This might be obvious - FCR´s/TDMR´s
Posted: Wed Sep 03, 2008 5:28 pm
Don´t forget the rubbers on our bikes are 38mm, i´ve actually been running 41mm carbs with 38mm rubbers for some time
Re: This might be obvious - FCR´s/TDMR´s
Posted: Wed Sep 03, 2008 6:41 pm
by steve speed
Posted: Wed Sep 03, 2008 6:48 pm
The tuner who did my extra head actually noticed it and he used his tuned dremel to take my spare rubbers up to 41mm.
Can´t believe i didn´t think of this myself......bugger!
Posted: Wed Sep 03, 2008 6:54 pm
by steve speed
lets hope you get some more bhp !! i wonder if it will make a difference
Posted: Wed Sep 03, 2008 6:58 pm
steve speed wrote:lets hope you get some more bhp !! i wonder if it will make a difference
Well, if it does not it´s anyway CORRECT...but i can imagine 41mm of air going into 38mm must mean some kind of restriction....
Posted: Wed Sep 03, 2008 7:05 pm
by steve speed
Posted: Wed Sep 03, 2008 7:08 pm
10?????? YOU GREEDY BASTARD!!!
Posted: Wed Sep 03, 2008 7:11 pm
by steve speed
Posted: Wed Sep 03, 2008 9:26 pm
by HansJ
Sorry lads, old news
The trickiest part is to get the rubbers correct in shape, they do change form when the inlet and carbs are mounted (at least mine did...). First time I used a small sharp knife, second time a Dremel. I doubt it makes a lot of difference, who knows, the mixture may even benefit from the extra turbulence...
Posted: Wed Sep 03, 2008 11:22 pm
by madivi
I start to imagine some pulsating snorkels, so thin they are to become
So at certain revs you're gona getting kind of a pump effect.
Beside the extra turbulence.
If that's not going to bring some extra 10 BHP?
You can do it if you really want...lalala..la..la
Posted: Thu Sep 04, 2008 12:38 pm
by Kayla
You might be better off trying to reduce the diameter down from 41 to 38mm gradually if there's enough length in the carb rubber to match the inlet tract and keep the gas speed up. A sudden increase in area, either up or down, is A Bad Thing. Failing that, I'd suppose it'd be a case of opening up the carb rubbers and matching the inlet tract to them.
Posted: Thu Sep 04, 2008 12:43 pm
Kayla wrote:You might be better off trying to reduce the diameter down from 41 to 38mm gradually if there's enough length in the carb rubber to match the inlet tract and keep the gas speed up. A sudden increase in area, either up or down, is A Bad Thing. Failing that, I'd suppose it'd be a case of opening up the carb rubbers and matching the inlet tract to them.
Yup, my inlets are taken up to match all way thru....with piranha teeth in them
Posted: Thu Sep 04, 2008 4:50 pm
by Greg
Pulsating snorkels ... ooooh Vicar!
Seriously though, I was watching mine last week, and at tickover there's an appreciable bit of movement in the carb rubbers, carbs pulsing up and down etc... Might have something to do with not having an airbox on top to hold them down .
G
Posted: Thu Sep 04, 2008 5:11 pm
by steve speed
Posted: Thu Sep 04, 2008 8:42 pm
by steve speed
the plot thickens ,,ive just had a look at some more spigots that trixynut gave me, they are for the 41s but they are a bit shorter in length and they are 41mm at the carb and 38mm at the end that goes into the rubber so there must be loads of different ones i am going to stick with the long ones that trixynut had on his bike and just blend them in ,,, (i might get 104bhp with a following wind !!!
