Check your carb coolant pipes next time you service them...
Posted: Thu Apr 01, 2010 1:05 pm
... or sooner if you never have.
My right carbs coolant pipes (and in/out hoses) were totally blocked with crap when I had them off. Not even repeated blasts from the air gun/carb cleaner would clear them. Took a while to get all the gunk out, had to use a long and thin screwdriver on the hoses and eventually worked through the carb with a cable tie of all things! Food for thought...
