Downshift misfire
gsax
Downshift misfire
When blipping down the gearbox sometimes get a misfire, is this a common problem
gsax
Dee
gsax
Misfire wasn’t the right description, “pop†would be better; happens very occasionally when blipping the throttle changing down (only when giving it some stick) It doesn’t seem to be a prob’ it sound’s quite good, I was just wondering if it’s normal.
gsax
If it's only occassionally and when giving it stick, the most likley cause is unburnt fuel in the exhaust igniting when the gear is re-engaged.
This can be achieved (with very amusing effects in tunnels) by flicking the kill switch, cracking the throttle and then flicking the switch again - he he he!
Dee
It won't do your engine any harm, certainly if it's only happening occasionally. Sounds great, doesn't it?!gsax wrote:Misfire wasn’t the right description, “pop†would be better; happens very occasionally when blipping the throttle changing down (only when giving it some stick) It doesn’t seem to be a prob’ it sound’s quite good, I was just wondering if it’s normal.
- Jak
phuk72 wrote:This can be achieved (with very amusing effects in tunnels) by flicking the kill switch, cracking the throttle and then flicking the switch again - he he he!
I did it in Croatia last year and a local shielded his kid and lay flat on the pavement.................guess these folks still have bad memories
Most likely cause is a tiny leak at an exhaust joint, mixing air with the unburnt fuel...............
