FCR's running very rough
Posted: Sat Jun 08, 2013 5:40 pm
Just tried firing up my recent rebuilt 878 before Snetterton this coming Thursday.
Observed two things that may be of help to others.
Started readily even when cold but refused to idle and lots of back firing when held on the throttle before dieing.
Much cursing, plugs out, check for inlet leaks, vacuum tap and pump OK. About to strip carbs but before doing so lifted FCR overflow from catch tank. Ran perfectly.
The cause was the end of the overflow being immersed in the small amount of fluid in the catch tank. Must have been stopping fuel flow to the motor (pulling a vacuum in the float bowl???
Relieved its a runner with 4 days to go.
Second thing was potentially dangerous.
Drive output shaft oil seal was changed when I stripped the motor.
Noticed oil below bike after short run time and traced this to the output shaft seal.
Again cursed as not an easy fix with the motor in one piece. Thought of burning it, selling the FCR's and getting a KTM.
Then noticed on close inspection that the inner seal lip had flipped when the seal was put on the shaft and was facing outwards. Care with a small screw driver pushed this lip to face inwards towards the cases and now oil tight.
If I had not noticed this before Thursday, leaking oil would have ended up all over my 180 rear Diablo and I may have ended up on my arse. Maybe comes from rebuilding over 3 weeks and not enough asttention to detail.
Pleased I am ready to go and will be checking the seal regularly during the day so that I do not worry about it as I scream round Corams at 100mph.
Will let you know how the day goes.
