TRX engine into a.n.other frame??
ac@39
just looking into a few things at present with no idea of where it will end but does anyone know if there are any other frames out there that the trx engine will slot straight into??
inspired by san miguel
- Tarwetijger
Re: TRX engine into a.n.other frame??
You mean the TDM850 frame?
ac@39
not necessarily a TDM frame ... has anyone got it to go into another frame without modding the frame.. could be a honda or duke .. anything
- Tarwetijger
In a Honda frame without modding... That would be a weird coincidence!
There are custom built frames like Bakker and Spondon, but that's pretty expensive.
- Kevtrx849
- Moderator
A past member on here (Luke) had a CBR400 with the TRX lump installed. He had to grind some material off the clutch housing to make it fit ,but fit it did albeit very snugly. That engine now resides in my shed.
( HENRY FORD )
( HENRY FORD )
