bane wrote:I have finally decided to upgrade my brakes. I hunted down some silver spots on the other side of the world and I am eagerly awaiting their arrival. Braided lines- goes without saying... But what I have not decided on is a master cylinder. Clearly, from my many searches here on the site; a 14mm axial master is a huge improvement over the standard trx item in this application. Then the radial pumps are thrown into the mix. An R1/R6 later model 16mm radial gets a few mentions here but some seem to think there is too much brake lever travel with this combo? Has anyone found this to be true? 19x20 also seems a popular choice but seems to be the costliest of the lot. Is there an optimum size radial mc to match "spots", maybe from another make of bike?
I don't know which way to go here. Im thinking either stay with the tried and tested (and designed to work with 'spots') 14mm R1/R6 axial or the later model R1/R6 radial. Is the radial a huge step up from the 14mm and definitely worth it for a few extra dollars? Is the radial a bolt on swap or is there modification required? what about the brake switches are they the same plug ends?
the more I look into this the less certain I am.
Any feedback or advice appreciated.
cheers,
Bane.
G'day Bane, I'm running gold spots with the R1/R6 radial master cyclinder (Made by Brembo) & it's like a bought one!
Mainly cos it is.
Silver/Gold/Blue spots all have the same piston size AFAIK, so you shouldn't have any problems.
No problems with the brake switch, the terminals might have been a little smaller on the M/C switch from memory, but works fine.
It's a BIG step up from stock TRX M/C & 'spot' calipers & lever travel is fine. You're welcome to try mine out if you want.
The M/C has a bleed nipple on it, which is a big help, reverse bleed, then bleed the M/C, I had pressure straight away, then bleed the calipers.
The other good thing with using the R1/R6 M/C is that you can get more A/M lever options.
