Lower yoke stem
ac@39
Lower yoke stem
Post by ac@39 » Sun Apr 12, 2015 3:34 pm
have had a look but cant find the specific specs for the trx lower yoke stem ... have removed stem from what i believed to be a standard lower yoke only to notice that the top yoke is marked 4jh y-1 correct me if i'm wrong.. but fzr600?
couldnt find any markings on lower yoke so want to be 100% sure i have correct stem, so if any one can point me to or tell me the correct length/diameter would be great as was wanting to get spacers made up to fit into rsv lower yoke --
:D
inspired by san miguel
SDN
Re: Lower yoke stem
Post by SDN » Sun Apr 12, 2015 10:07 pm
There are several diameters - there is a drawing somewhere on the site I believe. If you aredespate I may be able to do a sketch - I am in the process of modify a stem at present
Re: Lower yoke stem
Post by cobbadiggabuddyblooo » Mon Apr 13, 2015 6:53 am
4JHY-1 is correct for the top TRX tree.
STEM DIAMETER 30mm at the base where pressed into the bottom tree and total length around the 277mm mark.
30mm offset from c of stem to centre of forks
ac@39
Re: Lower yoke stem
Post by ac@39 » Mon Apr 13, 2015 11:09 am
Thanks guys.. Will check stem I have see where I'm at
