by cobbadiggabuddyblooo » Sat Jul 04, 2015 1:49 pm
OK ditched the phone and on the laptop.. Now I can read what you found Dicky..
The diagram further down which now I can read which differs from what I've interpreted from what's written down on their description.
power 24/7 is red.. pin 8 on the top row
Ignition power is black...pin 2 on the top row
RPM is purple/black.... pin 1 on the top
Anode is obviously ignition power. (like a sacrificial anode
) turned on and off
deathtoll
by deathtoll » Sat Jul 04, 2015 2:22 pm
Ok
01 Purple black pin is the tacho
02 Black pin is ignition
03 Light blue Right indicator
04 dark blue high beam
05 Yellow white neutral
06 Orange left indicator
07 Brown dip
08 Red memory
09 BLANK
10 White black speedo
ROW 2
01 Pink other side of speed sensor
02,03,04,05,06,07 gears
08 09 green black negative
10 Fuel (which can be modded for temp)
deathtoll
by deathtoll » Sat Jul 04, 2015 2:23 pm
Everything is working fine except for the tacho
Will try tapping a wire on 12v & see what happens
deathtoll
by deathtoll » Mon Jul 06, 2015 7:36 am
Nope, no joy & zero response from the seller.
Maybe he will respond now that I have used the word criminals in the feedback :p
So looks like I'll be saving for one of these
http://kosonorthamerica.com/product/tnt-01/
deathtoll
by deathtoll » Mon Jul 06, 2015 8:10 am
by dicky » Mon Jul 06, 2015 9:55 am
I bought my Acewell from that guy in Mitcham. No problems with the deal and the price was as good as any I could get O/S.
The unit came with full instructions, all wires, connectors brackets, etc.
Koso are very similar and also come with all the stuff you need.
They cost more, but they work. I hope you didn't spend too much on the unit you already have.
deathtoll
by deathtoll » Mon Jul 06, 2015 1:25 pm
Nah it was a cheapie.
It was to get me by whilst converting things over until I could afford a better one
deathtoll
by deathtoll » Sun Jul 12, 2015 9:12 am
