Rich
I like your thinking mate, the thought had crossed my mindMincehead wrote:Leave well alone and run some K-Seal in the coolant: http://www.kseal.com/uk/
It `might` be ok after a while and running, settling, re-torqueing.
I hear what you're saying regarding the cam caps cobba........ spent a fair bit of time tightening them down to the correct settings, also used plastiguage to check the cam cap tolerances while I had everything apart just for piece of mind......for the sake of a few quid it's worth the effortcobbadiggabuddyblooo wrote:
And a simple note ...
( this is not directed at you personally cake man![]()
... I'm just stressing this vital point to anyone who removes the cams.
Cam caps need to be torqued to 10Nm and no more.
Tighten by hand, then to 5Nm and finally 10Nm in a x pattern.
I've seen a couple of Trx motors that haven't followed the torque specs and have had the cam lock due to over tightening the cam caps to the detriment of the motor. Ouch....
Hope your mobile again soon..
