Bearings
eddie
Bearings
Post by eddie » Fri Jan 08, 2021 7:21 pm
Starting to rebuild my engine after powder coating the casingsand not a clue about the bearings do I replace them all or reuse them any advice please
God is my judge
Tealman
Re: Bearings
Post by Tealman » Fri Jan 08, 2021 10:28 pm
Personally, if I'd gone that deep into an engine I'd replace them all.
Re: Bearings
Post by dicky » Fri Jan 08, 2021 10:50 pm
Having pulled it all to bits it would seem obvious to replace all wear items.
What condition was the engine in before you pulled it down? How many km's on the bike?
If it's low km's then bearings and such are probably all in good condition and my not need replacing.
Really up to you.
eddie
Re: Bearings
Post by eddie » Sat Jan 09, 2021 1:15 pm
Thanks for the advice guys ...the engine was sat for 5 years
With the plugs more or less out so the cylinders were
Rusted hence the strip down . Think il replace em
To be on the safe side
God is my judge
Rod.s
Re: Bearings
Post by Rod.s » Sat Jan 09, 2021 1:40 pm
They are cheep and available so replace them...
eddie
Re: Bearings
Post by eddie » Sat Jan 09, 2021 2:51 pm
Wheres the best place to source them
God is my judge
Rod.s
Re: Bearings
Post by Rod.s » Sun Jan 10, 2021 2:41 pm
eddie wrote:Wheres the best place to source them
Yamaha is the only known supplier, as each set it matched to the engine.
