Cloot
by Cloot » Thu Oct 21, 2021 4:31 pm
How do.
Just gone to change my ignition switch as mine is very worn and I fear the switch will snap soon as it's hit or miss if it'll turn on the first or twenty first try!!
Anyway first of all I can't get the security bolts out, any tips please?
And the switch I bought is a two plug, six cable switch and mine being a JDM model has one four pin plug.
Can I chop the cable/ plug off the old switch and solder the cables to the new six cable loom.
If so what cables go to what please?
Cheers me dears, Adam
jpe70
by jpe70 » Thu Oct 21, 2021 8:24 pm
First question is easy. Just drill the heads off the bolts starting with a small drill to get it centered and finishing with a 6 mm until the heads loosen and catches on the drill. Now just pull the lock off and usually the bolts are loose enough to wind out by hand or using a vice. They are common M6 just with special head.
Two. Can't really say, but generally just cut and weld. It's a very simple electrical system and the ignition switch mainly connects ignition and light to power not much else. I ditched mine completely and just have a set of buttons on my left handlebar. Red is main power, else is accessories, there are digital manuals with colored schematics available for download (here?).
Cheers!
Cloot wrote:How do.
Cloot
by Cloot » Fri Oct 22, 2021 4:30 pm
