cam chain
mickjmag
cam chain
Post by mickjmag » Wed Nov 19, 2008 7:33 pm
Hi All,
Have been having issues with the cam chain tensioner sticking and am looking at replacing it, so I figured that I'd check the chain as well while I'm doing it.
Does anyone know of any tricks to removing the chain from the engine or is it as straight forward as the Haynes manual says and is it hard with the engine still in the frame???
Cheers, Mick
Re: cam chain
Post by phuk72 » Wed Nov 19, 2008 9:52 pm
can be done with motor in frame. not especially difficult but can cause serious bother if not done correctly
and make sure you don't drop it :wink:
madivi
Re: cam chain
Post by madivi » Wed Nov 19, 2008 11:22 pm
phuk72 wrote:can be done with motor in frame. not especially difficult but can cause serious bother if not done correctly
Best prevention is to fix some 30 cm of copper wire to the chain befor undoing camwheels and stuff.
(My profile is still as stock as my Trixie is, this might change)
