Akrapovic Exhaust
Terzikat
Akrapovic Exhaust
Folks, I want to fit an akrapovic full system to my TRX with a carbon hexagonal can like Honks. Gericke's (my closest Akra dealer) says they only do them with the oval can. Does anyone know what part numbers I should be asking for?
Re: Akrapovic Exhaust
Why not ask them direct?
http://www.akrapovic.com/where-to-buy/f ... dealer/uk/
By the way,what`s happening with those FCR`s?
- Tarwetijger
I spoke to a Akra salesman lately and he said a full system for the TRX is not available anymore. Maybe this only accounts for the NL? I have send some e-mails around and from TTS (UK) it still seems to be available. They are not very fast with responding to e-mail though.
Indeed,if you go to the Akrapovic`home` site in the link I provided the TDM 900 is listed but not the TRX!
Maybe there`s stock sitting in warehouses that`s available but they don`t make them now.
TTS will definately sort you out with one,and whichever can you specify.
I`m certain the link pipe diameter will accomodate all their cans.
Terzikat
Thanks folks, I can only get a price for the whole system with toval cans from gericke so will try tts next
- Tarwetijger
TTS wrote:Sorry Tarwetijger, I have checked with the importers & the system has been discontinued in the last couple of weeks & there is no stock left.
I thought so...
If anyone knows where to get an Akra system, I'd be interested.
- slow codger
- Tarwetijger
The Akra system is listed on many websites but if you would ask for it or make an order, they'll tell you sorry, it's not available anymore.
What you need is a good copy,anyone near you with one?
You could maybe obtain dimensions etc from a kindly member with one fitted,the pipe routing wouldn`t have to be exactly the same as long as diameters and tuned length didn`t vary too much or there were no restrictive bends.
Although with modern pressurized gas pipe bending equipment that seldom happens anymore.
The traditional way of protecting brass tubing from kinking when making musical instruments is to freeze water inside the tube before bending it,I`m certain the same could be done with Titanium tubing.
The cans are easy,available pretty much anywhere.The absorbtion tube type of can is very easy to manufacture,all the materials are easily sourced too.
- Tarwetijger
My current thought is on buying downpipes for a TDM from KEDO (which is said to be less restrictive) and a single e-marked silencer, like a Laser DualSound. Then I will ask my father to weld it together (he's a teacher in welding).
- Tarwetijger
I contacted Zietech.de, they advertise a lot on evil bay:
Let the hurting stop!
Boohoo
Argh, last week he says !yes, ist not avilable anymore. We sold the last one last week.
Boohoo
What about the route I suggested?
I`ve made stainless front pipes from following the form of bent welding wire before now,it`s not that difficult to find a good fabricater in the Netherlands surely?
Perhaps the exotic titanium is outside some welders abilities,I`ve never tried myself although with a pulsed TIG system I`m pretty good at regular alloys just don`t have the equipment and need to borrow/beg it from contacts.
What about contacting custom exhaust manufacturers with high pressure nitrogen gas tube forming facilities too?
Some of the custom exhaust manufacturers in the UK are excellent,here`s one of `quality` I know of:
http://www.gibsonexhausts.co.uk/
Pete Gibson`s built exhausts for pretty much anything but mostly known for his stroker expansion chambers.
And I`ve heard a lot of good reports about the skills of Zorstec too:
http://www.zorstec.net/bikes.htm
Perhaps a `holiday` in the UK should be considered,on the bike of course,then return with your new system all fitted and shiny.
- Tarwetijger
Although your invitation is temptingMincehead wrote:What about the route I suggested?
8<
And its the lower restriction I want. Therefore I would like to try TDM performance downpipes (like I said here). I know that the exhausts of the TDM and TRX are rather different but I don't understand why it wouldn't fit - even with a bit of work, .
It must be hard because I haven't heard anybody else about TDM downpipes and stuff.
Edit: oh, another thing of importance: it shouldn't be too loud, because the police is paying more attention to bikers these days and I don't have to worry about noise limits on trackdays. The Akra systems came with e-mark approval signs, which is good to stay out of trouble.
