Valve clearances; Do I need to re-shim?
Norton850
Post by Norton850 » Wed May 02, 2012 10:50 am
Hi.
Thought this forum might be the best to check this query:
Checked my TRX valve clearances: Meant to be 0.15 to 0.2 mm inlets
Are actually 0.27 to 0.29 mm inlets
Do you think that they need reshiming; 0.07 mm doesn’t sound a lot... or does it?
Regards,
Paul.
Re: Valve clearances; Do I need to re-shim?
Post by Killerwhale » Wed May 02, 2012 10:59 am
Norton850 wrote:Hi.
Regards,
Paul.
You are in the region where you hear a distinct tick when the cam hits the bucket, you also miss out on lift.
All i can say, i would!
Post by Mincehead » Wed May 02, 2012 11:20 am
Tolerances exist for good reason, outside of tolerance? Replace the shims, simple as that. :wink:
As for why?
Think of a hammer and a well used cold chisel, note how the end of the chisel that get`s struck tends to deform and curl over?
Deformation can and does occur in components of a valve train if tolerances are ignored, plus your TRX will start to sound `unhealthy` too.
Go to page 21 of 306 on the repair pdf (downloads section) of the forum, you`ll note tolerances quoted for ALL the components that rotate or open / close and play their part in the combustion cycles inside your engine. :wink:
Norton850
Post by Norton850 » Wed May 02, 2012 12:35 pm
thanks for that will resim them then get a tune
Post by phuk72 » Wed May 02, 2012 12:49 pm
Norton850 wrote:Hi.
Regards,
Paul.
.07mm may not be much in terms of size but it's 35%
what you'll find is that you can probably move shims around to give you the tolerances you need which will limit the number of replacements you need. Yamaha used to do swaps as well
