Any tips for cleaning out the bobbins on the TRX stock front discs? Most bobbins have a hole through the centre so it is just a case of threading a bolt through and spraying in some brake cleaner while turning the bolt but the TRX discs have no hole through the middle, which makes it tricky.
Any tips?
Brake Disc Bobbins
- Con Rod
Brake Disc Bobbins
Re: Brake Disc Bobbins
- Con Rod
cheers Mince, I was waiting for the sum to rise in Jockland for your response. I will do that
At 5.24 pm it was about to set Rod!
Naaaa, not really, at this time of the year it hardly gets dark at all here, at any time. Although saying that, it`ll slowly creep in after the longest day which is the 21st.
