I bought a set of
used FCR41s(with TPS) + RAMAIR filter a few months back. I finally got around to fitting them to the bike last night. The bike fired up OK
...but I have a fuel leak coming from somewhere on the carbs. I can see the occasional drip of fuel coming from the middle area at the rear of the carbs that drips down between the cylinders and oil tank. The carbs are also moist with fuel on both side on there edges and bottoms. (I'll try and post some pics!).
As I didn't get any instructions with these carbs I'm not sure on a few things:
1. What should the accelerator pump be set at?
2. Could the above be caused by the accelerator pump being set 'on' too much?
Just FYI the bike is idling OK. When I blip the throttle the engine chokes itself (from reading on here I know that FCRs can behave this way).
The engine is stock apart from the FCRs and was running fine with the stadard carbs.
Thanks,
