Running poorly after new shims
- Jeff8
Re: Running poorly after new shims
Super, thanks Cobba, I don't think he has started yet so I may just get them back & go North.
- Jeff8
Well I am picking them up today & will go visit up north hopefully tomorrow.
I searched long & hard through old posts & there was some suggestions that maybe the floats or at least one was not quite right & I had one around 11mm & one at nearly 15mm so I adjusted them both to 11mm & it goes much better now. Sucking in air from everywhere with everything off it so still runs a bit rough.
Just one question though, no one actually mentioned just where to take these measurements from so I measured from the bottom of the float bowl to the bottom of the floats pushed up to get this figure. Let me know if this is the correct method.
- Con Rod
it is pretty tricky and you need a clear tube on the drain hole. There is a line on the side on the carb. You want to adjust the float tangs to get the fuel level to 5mm below that line, pictures belowJeff8 wrote:Well I am picking them up today & will go visit up north hopefully tomorrow.
