Fuel consumption and mixture
meemo_meh
Post by meemo_meh » Mon Apr 30, 2007 10:01 pm
How long has the bike had the kit in it? Was it tuned after they were put in? The main diff I found wasn't the fact that the kit was put in, it was mainly the tuning as out of factory these things run very very rich. (Like the juice ;-) ) Not to mention my needles were worn and the tubes were ovalled out. I will check the DynoKit packet contents, think I still got it all in the garage....
Glen1TRX
Post by Glen1TRX » Mon Apr 30, 2007 10:04 pm
Wombat wrote:Try Bikebiz, Parramatta - they've a wealth of knowledge on TRXs. Their boss once built one with Ohlins everything and an Akrapovic 2-1. Don't know if they've still got it. I saw it under a sheet at the back of the shop a few years ago. Beautiful!
I saw it there last year Bob - uncovered KRJ color scheme from memory
time fades away
meemo_meh
Post by meemo_meh » Mon Apr 30, 2007 10:12 pm
Okee Dokee.. One point to Phuk 8)
DynoJet contents: main jets, main jet o'rings, fuel needle, washer and e-clips.
My emulsion tubes must of been ordered as an extra when it was tuned, I had just assumed that it came with the kit.
But yeah, order in some emulsion tubes, have it tuned by someone that you know is good at it and have them check the condition of the rest of the parts for wear.
CULater
Post by CULater » Mon Apr 30, 2007 10:35 pm
Emulsion tubes are not included in a Dynojet-kit (i sell 'm so i need to know)
It's standard tubes with Dynojet needles. (normaly the tubes get replaced
when a kit goes in)
[JP]
Post by [JP] » Tue May 01, 2007 9:40 am
Ok guys!
Thanks for the help..
Regarding when it was dynojetd and if it was retuned… I don't have a clue…
My bike was an ex Harris Performance bike so I suppose everything was done properly?
But…the engine has been changed, the original engine was raced and the previous owner had problems with the engine and replaced it for another one with less miles, know this is true cause I saw the engine in his shed and all the numbers matched…
So, probably my plan of action will be:
Get emulsion tubes
Strip the carbs, clean it and change the emulsion tubes.
Check air filter and replace or clean
Set the carbs properly
Should do the job!
Image PORTUGUESE MADNESS
Post by phuk72 » Tue May 01, 2007 11:02 am
meemo_meh wrote:Okee Dokee.. One point to Phuk 8)
culater wrote:Emulsion tubes are not included in a Dynojet-kit
OK, no need to keep telling me I'm right, from now on in we'll just assume that :wink:
if the bike was set up fro a race engine and jetted accordingly, there is every chance it will be jetted incorrectly for a standard lump. Combine this with worn tubes and you'll have the answer.
best bet is to rejet to standard (144 IIRC) and replace tubes and tinker from there on in
Wombat
Forum Marsupial
Post by Wombat » Tue May 01, 2007 11:28 am
If think they actually might be 142.5 standard, but correct me if I'm wrong. That's what it says in the Haynes manual and on my Factory Pro emulsion tube and Jet kit which arrived yesterday.
Post by phuk72 » Tue May 01, 2007 1:40 pm
Wombat wrote:If think they actually might be 142.5 standard, but correct me if I'm wrong. Bob
you are spot on - it is 142.5 :oops:
been a long tinme since my motor was in standard trim
meemo_meh
Post by meemo_meh » Tue May 01, 2007 10:17 pm
Onya JP! Let us know how that goes.
[JP]
Post by [JP] » Wed May 02, 2007 9:01 am
I will.. I will... still have to go to Pro-bikes and order the emulsion tubes...
Will probably try to do an How-to with a few pics.
Wombat
Forum Marsupial
Post by Wombat » Wed May 02, 2007 11:15 am
Gotta do it very soon. Thing's running like a dog down low - very flat - above 3 and a half to 4, it picks up and runs normally. Very frustrating! plus its starting to get cool here, at least in the mornings, and I'm running Motul 5100 15W50 with only 12kms to work,so it's not really warming up to any degree. Bought some 10W40 today and will put it in plus some new plugs on the weekend, before it goes in for the jet kit. Hopefully its not something extra like the clutch or the coils going :(
[JP]
Post by [JP] » Wed May 02, 2007 1:57 pm
geezz..just got in from pro-bikes... 20quid for each emulsion tube!!! :evil:
lloegrfach
Post by lloegrfach » Tue May 08, 2007 8:24 pm
Hi,
I'm just getting everything ready to do the same job - Dynojet kit, filter, emulsion tubes...
Where did you get your tubes from? I tried my local Yamaha dealer and drew a blank. The man on the phone asked "is it a pipe or something?" :roll: .
I did read somewhere (on here?) that there is a Factory Pro dealer in the UK. I've tried Dynojet but they cannot help me without a part number - anybody help there?
Anyway, good luck with the work - a "Step by step" guide would be great!!
Richard
Post by Killerwhale » Tue May 08, 2007 8:29 pm
lloegrfach wrote:Hi,
Richard
"emulsion tube" is a quite old name for the same thing....
"Needle jet" should everyone although 20 years old get...and the thing in there is the jet needle... 8)
Tourqe-a-holic
lloegrfach
Post by lloegrfach » Tue May 08, 2007 10:09 pm
Emulsion tubes, needle jets, 1-1/4" long brass tubes about 3/8" diameter - I tried it all. I'm going to try again in the morning - I might be able to speak to a mechanic!
Any idea of the correct part number for the tubes (needle jets)??
Thanks,
Richard
