by slow codger » Wed Jan 23, 2008 10:36 pm
Billy , checking out to see If daughter can sort out bearings ( she works for a place that packs them, and they do KOYO), If she does the price will probably be a lot cheaper.
Anyone know If an FZR600 front will fit the 750 forks?
by phuk72 » Thu Jan 24, 2008 8:40 am
slow codger wrote::
Do you mean FZR750 or YZF750?
YZF forks deffo too big
by slow codger » Thu Jan 24, 2008 6:46 pm
Yzf front forks, what other wheels will fit? FZR, R1, R6, Thunderace, thundercat or others?
billy budge
by billy budge » Thu Jan 31, 2008 8:09 pm
Right now all the blunders have been made right, they ordered me bearings from a pre 99 model wheel and ive got a post 99 wheel!!, ive got the bearings and spacer back in now.
Just to elaborate on honks reply about the spacer should be lightly retained and not flopping about, i dont know whether or not i should nip them up a bit more. The spacer isnt flopping about but if you push it with your finger with medium pressure you can move it, is that tight enough or not please vicar??
Cheers.
honkdawillydahonk
by honkdawillydahonk » Thu Jan 31, 2008 8:18 pm
Cheers.
That sounds about right to me...
billy budge
by billy budge » Thu Jan 31, 2008 10:11 pm
Ahh honk my boy, many thanks buddy.
I can get the beauty balanced and back on tomorrow, ready to go in the van on saturday.
Cheers.
by Greg » Thu Jan 31, 2008 11:32 pm
Bill...
Think about the line of force ...the spindle nut acts on the forkleg, which acts on the
inner race which acts on the spacer..other inner race ... other forkleg... spindle flange !
I made the mistake of banging my bearings in too tight (thinking that the wheel machining and bearing sockets would have been worked out with maths) but I ended up with the bearings 'nipped' and therefore running tight as the outer races were out of alignment with the inners (which had been held apart by the spacer...). I - very carefully - knocked the bearings out a snidge which solved the problem.
HOWEVER, you can end up also nipping the bearing by not driving the outer races far enough into the wheel - think
about the lines of force applied by the spindle which will also pull the inner race out of alignment...
Get it just right
and everyone's happy!
billy budge
by billy budge » Fri Feb 01, 2008 9:11 am
Cheers matey, very wise and interesting words.
At least now i know what to look for if and when that situation arises and i already have the solutions!!!
Cheers.
by slow codger » Fri Feb 01, 2008 9:33 pm
Billy, do you have the old bearings? I need them so that daughter can take them work to see whether they are the same as all the car ones. They possibly do them, but need to know numbers and sizes.
