My YZF swinger....
Re: My YZF swinger....
Post by youngy » Mon Jul 07, 2008 2:01 pm
which nut? rear wheel axle or swingarm pivot?
steve speed
Post by steve speed » Mon Jul 07, 2008 2:04 pm
i mean rear wheel !! what do you mean? :lol:
Post by youngy » Mon Jul 07, 2008 2:13 pm
steve speed wrote:i mean rear wheel !! what do you mean? :lol:
wasn't talking to you! [-( :tongue:
but...................with the nut on the left, as it should be, I've found it easier to get the spindle through the swingarm and caliper bracket together. with it on the other side I found it fiddlier (?).
Of course, the swingarm pivot can only go one way :!: :lol:
Post by Killerwhale » Mon Jul 07, 2008 2:31 pm
I just took it for granted it was the same way as the TRX but then saw all theese pics of it the other way around.....rearwheel spindle that is.... :wink:
Post by HansJ » Mon Jul 07, 2008 2:53 pm
I had no probs with standard sprockets with the YZF wheel (I guess it's an YZF at least). But the Marvic wheels seem to be a touch wider, causing the same problem. I bought chain/sprockets from AFAM, the front sprocket was dished, so putting it in the "wrong" way I gained a little, but I had to add two of the locking washers on the inside of the sprocket. Now it's about right... One thought, which spcaers are You using for the YZF wheel? Dimensions? I can have a look later in the week what dimensions mine have.
Post by Killerwhale » Mon Jul 07, 2008 2:59 pm
HansJ wrote:I had no probs with standard sprockets with the YZF wheel (I guess it's an YZF at least). But the Marvic wheels seem to be a touch wider, causing the same problem. I bought chain/sprockets from AFAM, the front sprocket was dished, so putting it in the "wrong" way I gained a little, but I had to add two of the locking washers on the inside of the sprocket. Now it's about right... One thought, which spcaers are You using for the YZF wheel? Dimensions? I can have a look later in the week what dimensions mine have.
Yup, we´ll do that....i have to check what´s up with my rear caliper anyway so i´ll check tonight!!
Post by slow codger » Mon Jul 07, 2008 3:16 pm
Rear sprocket is a 41 tooth, no make on it though.
Silly thought but you did take the pads out of the rear carrier before trying to fit didn't you?
Post by Killerwhale » Mon Jul 07, 2008 3:18 pm
slow codger wrote:Rear sprocket is a 41 tooth, no make on it though.
Pads....do you mean the cush drive rubbers??
Post by slow codger » Mon Jul 07, 2008 3:22 pm
:D disc brake pads.
Post by Killerwhale » Mon Jul 07, 2008 3:24 pm
slow codger wrote::D disc brake pads.
Ahh...i didn´t even had the brakepart installed...that was the last thing i did after lining up the chain! :)
Post by slow codger » Mon Jul 07, 2008 3:29 pm
:? I have spacers being made for the wider wheel, but when I was lining everything up my rear brake carrier didnt line up, so I have a spacer between the wheel and the carrier, and also between the carrier and the swinging arm.
Post by Killerwhale » Mon Jul 07, 2008 8:50 pm
...i saw tonight that the brake actually don´t line up either....WTF???
Post by Killerwhale » Tue Jul 08, 2008 7:22 am
So, i never did measure how much the brake disc should go to right but it´s for sure 4-5mm....and as i needed to put in a 6mm spacer for front sprocket it´s starts to smell fishy...
The seller dwells on the German forum but i get the silent treatment as i guess he has no clue and hoping i won´t be going to Germany any time soon....
But...what could have happen here....wrong wheel all together? .....wrong spacers??
Should i just ask someone to make a new 6,5mm spacer for the right side and add the same to the left....maybe easiest and also best so i don´t put extra stress on the output shaft?
Post by slow codger » Tue Jul 08, 2008 9:28 am
:? Getting them back at the end of the week, so will post dimensions then, as I left them with the person who is making them for me.
Post by Killerwhale » Tue Jul 08, 2008 9:38 am
slow codger wrote::? Getting them back at the end of the week, so will post dimensions then, as I left them with the person who is making them for me.
Top!!
