G Beale wrote:Cheers all, brakes can wait, I just bought the ebay factory pro tubes tonight so fingers crossed it should cure my very snatchy on/off throttle & reluctant warm starting ?
I just got 150 miles from nearly full to reserve, is that bad ?
Note that if the bike has had cans and a DJ kit on it and the original cans put back on, it may not be jetted perfectly - your emulsion tubes (a.k.a. needle jets) may not be the sole cause of this.
Check all the jet sizes are correct and clean them all up carefully, plus check needle clip setting, when you do the job.
Since you have the factory pro tubes to do, I would suggest, if you haven't already, that you
get ALL the carb gaskets and o-rings from Yamaha. They probably are fecked - they certainly were on my '97 bike when I did the job two years ago, and once you take everything apart, they likely won't reseal properly.
I had also heard suggestions (maybe from Factory Pro, actually) that the cause of the wear is the fit between carb slides and the carb body (movement causes needles to erode the emulsion tube walls), and that it's preferable to replace the slides when you do the emulsion tubes.
As people have said, throttle cable and chain make a difference with these bikes, so check throttle is set spot-on, the chain is properly adjusted, the rear wheel is properly aligned (well, at least the adjuster blocks!) in the swingarm and the back brake isn't dragging before you work on the carbs.
On the brakes, any blue spots will fit. Non-radial six pots are not off an R1, but I think I know the ones you mean. Are they FZ1? Something like that. No idea if they fit, but you most likely won't see any meaningful benefit from anything more than decent blue spots & matching master cylinder (TRX one has a larger internal diameter and doesn't give as much braking power). Don't honestly think the bump damping (what fast bump?) on the stock forks would like anything stronger than blue spots, plus you may just be adding unsprung weight in return for extra pad area that you really don't need on a 190kg, 135 mph bike (bit different if you're trying to keep the brakes cool on a 270kg, 190mph Hay Abusa'...).
