G Beale
by G Beale » Fri Dec 19, 2008 4:27 pm
Here's where the cans finish up.
Only pic I have at present but will take more when it's all bolted on properly.
by Killerwhale » Sat Dec 20, 2008 2:44 pm
G Beale wrote:Thanks Greg, I like it.
I've had it on the bike loosely fitted & it all goes where it should so I'm sure it was designed for the TRX. Cans are quite small at 100mm diameter... . or is it the standard cans that are huge ?
My Kawasaki header clamps came today & they fit so just waiting on gaskets now & I can fire it up.
I discovered yesterday that my Ford CVH cylinder heads have exactly the same exhaust studs as my TRX !
Didn´t you see in his add on ebay that it was a one off made for a trackbike??
G Beale
by G Beale » Sat Dec 20, 2008 3:25 pm
You pay more attention than me mate.
Here's the text from the ad'.
a yamaha trx 850 race system
which was professionally made for race bike
unusual 2 into 4 into 2 system, designed to give max power
needs new sleeves fitting they cost 80 pounds
and could do with a repaint otherwise in good sound condition
That's solved it then, it's unique !
G Beale
by G Beale » Wed Dec 24, 2008 2:11 am
by youngy » Fri Apr 24, 2009 9:52 pm
Greenhill Racing i think. Extremely expensive high flow custom race pipe. The 2-4-2 design flows as much as an enormous diameter 2-2 does.
G Beale
by G Beale » Fri Apr 24, 2009 10:51 pm
Blimey ! Cheers for the info youngy.
It is very well made, looks like someone went to a lot of trouble & it fits perfectly which is unusual for something that is a "one off". I can imagine it would have cost a lot new but I didn't pay all that much for it.. . . which was nice.
Just out of curiosity I will look these Greenhill racing geezers up then.
Thanks again.
G Beale
by G Beale » Sat Apr 25, 2009 12:34 am
by Mincehead » Sat Apr 25, 2009 1:13 am
It would seem their site is `under construction`,what`s your excuse?
devlin
by devlin » Sat Apr 25, 2009 8:18 am
Mmmmm.... they do Rotrex!
by cobbadiggabuddyblooo » Sat Apr 25, 2009 8:27 am
aahhh yes keen on supercharging... devlin...
devlin
by devlin » Sat Apr 25, 2009 11:15 am
Very much so. I can get one local for about $2300 from memory. I'll build up a fuel injection and plenum setup from parts and probably use Megasquirt. But I haven't worked in a week and a half so very low priority at the moment. Then it's a toss up between doing that or getting the Mustang shell and starting on that.
I really like that exhaust that GB got. Not fussed on carbon though. I reckon brushed Al of Stainless would be the go for me. Does look ace but.
G Beale
by G Beale » Sat Apr 25, 2009 11:50 am
Mincehead wrote:It would seem their site is `under construction`,what`s your excuse?
No excuses, I'm tight & it was cheap !
Maybe I'm not seeing the full potential of this exhaust as the carb's are standard bar the factory pro tubes & I'm still running standard air box with K&N filter. I should at least try a dynojet kit but having another project on the go means time/money is always well stretched for me. The bike is winning over the car so far this year, I've just bought a pair of FZR600 foxeye front forks for it & a pair of pirelli dragon corsa pro evo super duper what ever the f**k they call them tyres.
Having said that the bike still pulls strong right up to the red line.
When the exhaust turned up the cans were painted mat black. 1 was ally & the other carbon but the seller included 2 new carbon tubes so I fitted them. I bought 2 oval cans from Brockzilla a few months back but they need a bit of cutting/welding to fit this system so not done anything yet. Sure they will look better than the stubby round ones just can't find time to fit them.
devlin
by devlin » Sat Apr 25, 2009 3:05 pm
So many projects. So few weekends.......... and pay days.
by dandywarhol » Sat Apr 25, 2009 5:06 pm
I've found the Dynajet kit v. difficult to setup properly - the FPs were easier but very suseptable to correct float height.
