headstock bearing replacement
Re: headstock bearing replacement
Post by cobbadiggabuddyblooo » Thu Feb 02, 2012 7:42 am
I know those few shots of vodka help with my bike...he he he he
drix
Post by drix » Fri Mar 02, 2012 10:09 pm
Had a bit of a search but didn't much on head bearings but didn't really find much other than this thread. I guess it is best practice to replace headstock bearings but I was wondering if there was a way to remove the lower bearing without messing it up and place it onto another stem/yoke?
Adrien
Post by alextrx850 » Fri Mar 02, 2012 10:40 pm
drix wrote:Had a bit of a search but didn't much on head bearings but didn't really find much other than this thread. I guess it is best practice to replace headstock bearings but I was wondering if there was a way to remove the lower bearing without messing it up and place it onto another stem/yoke?
Adrien
Drix..the oem steering head bearings are of the caged ball bearing type..with a one set on the lower and as i found two sets to the upper....when i ordered my new set from my Yamaha dealer, they came as tapered rollers ,and one for the lower.. and one for the upper race...same for a trailer wheel bearing.!...just tension up the new system until nil play is had, and lock the top nut down...delightfully simple
The lower steering bearing ..can be removed by heating the locking collar with a blow torch to expand it and carefully working around the base with a wood chisel useing the lower bearing race to push off, the bearing wil be the same which is why a new one would be the best way for a best job scenario.
drix
Post by drix » Sat Mar 03, 2012 12:41 pm
Adrien
I did think of heat but that would damage the dust seal at the base of the lower bearing so I guess a new one it is then. Went to Yamaha this morning... circ £50 for the lower bearing and £40 for the upper... I guess they don't sell many very often at that price and I ordered online instead! :lol:
Post by slow codger » Wed Mar 21, 2012 10:31 pm
:shock: Have you tried a local bearing manufacturer/stockist? they may well have something the same, and probably a lot cheaper as well.
Post by Mincehead » Wed Mar 21, 2012 10:33 pm
M.V.
Post by M.V. » Wed Mar 21, 2012 11:42 pm
alextrx850 wrote: The lower steering bearing ..can be removed by heating the locking collar with a blow torch to expand it and carefully working around the base with a wood chisel useing the lower bearing race to push off, the bearing wil be the same which is why a new one would be the best way for a best job scenario.
Any ideas on getting it back on? Last time I took the bearing & stem to an engineer who pressed it on, is there a DIY way?
I have new bearings sitting on my desk at work :)
Post by Mincehead » Wed Mar 21, 2012 11:50 pm
Plumbers pipe freezing spray on the stem and heat the bearing GENTLY in the oven to around 100 degrees. :wink:
M.V.
Post by M.V. » Wed Mar 21, 2012 11:55 pm
Mincehead wrote:Plumbers pipe freezing spray on the stem and heat the bearing GENTLY in the oven to around 100 degrees. :wink:
Groovy, I'll give that a try. Cheers Mince.
