AndyAshworth
by AndyAshworth » Thu Nov 22, 2012 5:26 pm
xxr55 wrote:cobbadiggabuddyblooo wrote:the std TRX spring rate is suited for a 76kg rider but the weight of a TRX is around the 207kg mark std..
No wonder I've always enjoyed the TRX ride. I weigh 76kg. How lucky.
I wish I was lucky enough to weigh 76kg
Stankflapper
by Stankflapper » Thu Nov 22, 2012 7:52 pm
coxylaad wrote:I get no sag from grabbing the throttle
You shouldn't get any sag from grabbing the throttle and hard acceleration. The back end should actually lift up if anything.
its true
the only thing that lifts from hard accel on my bikes is the front wheel.. I think you are confused
by fung » Thu Nov 22, 2012 8:10 pm
'the only thing' 'thats hard' 'lifts on acceleration'
Fung
by coxylaad » Thu Nov 22, 2012 9:35 pm
Any of you ever read a book called A Twist of the Wrist by Keith Code.
I recommend you read it, there is also a dvd available to download too. its awesome, explains everything what is happening with both the bike and you through the whole range of motorcycling situations - including the one above.
by dandywarhol » Thu Nov 22, 2012 10:37 pm
I go with whats in the link but there's still more to it and that's to do with the position of the swing arm pivot/gearbox output centre line and general weight transfer under acceleration
by dandywarhol » Fri Nov 23, 2012 12:28 am
I'm not argueing with you Ian - I've watched my own bike lift on the dyno but in reality other factors more than cancel it out and make the back end squat down to improve grip - except the ol' Beemers which rode up the final drive pinion
Stankflapper
by Stankflapper » Fri Nov 23, 2012 6:35 am
As a result, the motorcycle moves forward and, because the upward force is behind the bike's CG, the rear-end of the bike moves UP. You will also observe if you look closely that as the angle of the swing arm increases, the wheelbase decreases. THAT is the significance of an upward pointing swing arm.
I suppose it is the way you interpret. To me it simply means you are doing a wheelie
Stankflapper
by Stankflapper » Fri Nov 23, 2012 6:37 am
dandywarhol wrote:I'm not argueing with you Ian - I've watched my own bike lift on the dyno but in reality other factors more than cancel it out and make the back end squat down to improve grip - except the ol' Beemers which rode up the final drive pinion
The dyno lift effect is the rear wheel trying to climb the roller, this is why they are tied down.
