Sparkplug cap into cylinder......
Post by HansJ » Sun Jul 01, 2007 8:31 pm
No need to pull the engine out, You would only need to take the cylinder head off. Taking it all off, and putting it back again, would be doable in about 6-8 hours for a first-timer with some basic experiences, unless something un-expected happens (which of course will happen, so why call it unexpected...). You'd need an extra long allenkey ("förlängd insexhylsa", 6 mm me thinks?) for the cylinder head bolts, and a torquewrench for tightening the head bolts, except for that, standard tools will do fine.
Post by phuk72 » Sun Jul 01, 2007 10:46 pm
And a new head gasket
haggisbash
Post by haggisbash » Mon Jul 02, 2007 11:49 am
Ahh, at least you know the little beggar is in there :wink: Soooooo, I still reckon if you get a thin welding rod - the brass kind, fold the end of it back on itself with a little piece of cotton cloth wedged in it, cover this in sticky grease or maybe sticky chain lube then go fishing :) Dont use engine oil, baby oil or "boy lube", these are all too thin and slippery to be effective :lol:
Janitor
Post by Max » Mon Jul 02, 2007 1:08 pm
haggisbash wrote: "boy lube"
:ky: :?:
:shock:
Post by phuk72 » Mon Jul 02, 2007 7:51 pm
Yeah - wot he said ^^^^ WTF :shock:
Post by Killerwhale » Tue Jul 03, 2007 7:08 am
:ky: :?:
:shock:
:sign5:
Post by Killerwhale » Wed Jul 04, 2007 7:41 pm
haggisbash wrote:Ahh, at least you know the little beggar is in there :wink: Soooooo, I still reckon if you get a thin welding rod - the brass kind, fold the end of it back on itself with a little piece of cotton cloth wedged in it, cover this in sticky grease or maybe sticky chain lube then go fishing :) Dont use engine oil, baby oil or "boy lube", these are all too thin and slippery to be effective :lol:
Nope. no way....haven´t got any "boy lube" though....you reckon that would work!? :lol:
No, it´s tearing it or get help from a friend and turn the bugger upside down!
Will stop at the Yam workshop and see if i can get a tech to give some tips....soon one month without riding....kinda glad it´s raining cats+dogs....worst June since starting readings late 19th century......
Sp!ke
Post by Sp!ke » Thu Jul 05, 2007 4:15 pm
Digital camera with a flash, put it on manual focus for right distance, hold it 6" away from the hole and take a picture.
Flash should provide enough light down the hole and you should be able to see whats going on down there in order to retrieve the damn thing.
Hoover with a bit of fuel hose gaffer taped to the end will suck up anything like this in a hurry.
Post by HansJ » Thu Jul 05, 2007 4:37 pm
Sp!ke wrote:Digital camera with a flash, put it on manual focus for right distance, hold it 6" away from the hole and take a picture.
I want to have a camera like that! So far I haven't seen anyone though... The piston is leaning forward, the cylinder is 89 mm wide, peeking in through a hole that's about 17 mm wide from a distance of 150 mms, what more information would a camera shot give compared to take a peek by Yourself?
And while I am being grumpy, KW, spend more time trying to fish for the cap than You spend discussing it on the internet. You'd probably had it out long ago... :)
Post by Killerwhale » Thu Jul 05, 2007 5:43 pm
HansJ wrote:And while I am being grumpy, KW, spend more time trying to fish for the cap than You spend discussing it on the internet. You'd probably had it out long ago... :)
Yeah yeah yeah!!! :lol:
Janitor
Post by Max » Fri Jul 06, 2007 12:16 am
You tell him Hans! :lol:
Sp!ke
Post by Sp!ke » Fri Jul 06, 2007 12:55 pm
HansJ wrote:I want to have a camera like that! So far I haven't seen anyone though... The piston is leaning forward, the cylinder is 89 mm wide, peeking in through a hole that's about 17 mm wide from a distance of 150 mms, what more information would a camera shot give compared to take a peek by Yourself?
Ahh... didnt realise it had gone as far down as the piston crown.
Still recon there's a good chance by attaching a fuel pipe to the vacuum though.
Sarg
Post by Sarg » Sun Jul 08, 2007 8:13 am
Totally. That is what I would do
Post by Killerwhale » Thu Aug 16, 2007 7:45 pm
Well, i guess it´s time for an update here.
The fekkin little bugger is out, my mates where all busy....go figure...so i had to hold the head with one hand and fish out the cap with the other....probably kodak moment!
Anyway, with my slotted wheel and tired mind i guess i managed to set the exhaust cam a tad wrong so i had no comp and it was shooting fire into the downpipes....they where HOT after just 5 sec.
Will set timing again....and right on saturday...with some preparing on friday.
As HansJ said on Swedish forum, learning a lot the hard way....and why not!?
...and yeah, my exhaust system is on evilbay! :twisted:
haggisbash
Post by haggisbash » Fri Aug 17, 2007 7:50 am
Hooray its out :cheers: Better flames in the exhaust than piston meets valves :lol:
