whats the blue plug do? HEEEEEELLLLLPPPP
Posted: Sat Mar 29, 2014 9:43 am
Replacing my wiring loom. Got a second hand one from a '95 model, mine is a '96 (maybe '97). Edit, Australian model, silver frame
There is a different plug arrangement, anyone got experience??
(under the tank)
on the later model, there is a 3 pin flat plug junction, a "sky blue" wire goes to the starter interupt thing (I am assuming this is the neutral light on the dash, its not working)
a yellow wire tees to the headlight and turn indicator plug and to the left handlebar switch assy
a dark green wire tees to the headlight and turn indicator plug and the left handlebar switch assy AND the rear indicator (right side)
With this plug DISCONNECTED I am getting rear turn indicators OK but no high beam or neutral dash lights.
On the earlier loom there is no plug to match this one above but a spare BLUE colored plug. This plug has 6 smaller pins, one pin has no wire connected.
Wiring color is Black (blue stripe) Yellow, red (blue stripe) blue and dk green.
I cannot find this plug on any wiring diagram that I have
WTF do I do with it? Do I need to meggar every connection to see where the wires go? (OMG)
(under the tank)
