Now, here's the list of new keihin owners questions!
1) Is there a user's manual anywhere - does anyone have a copy I can copy or borrow or scan??
2) in the absence of the above, I can't at first sight see how they are synchronised - any help or don't they need it?
3) Looking at the carbs from the top, there is a pair of joining tubes with spigots - the bottom is the fuel inlet (well at least I hope it is!) .. is the top one an overflow outlet??
4) Assuming that the bottom spigot is the fuel inlet, mine is pissing fuel out quite badly - are the carbs easily separated and are the seals easily replaced (now you see the relevance of the sync question eh?) but what I don't want to hear is that I've been filling the carbs via the overflow spigot
And... then there's the question of the TPS ... I've seen the wiring mod and as far as I can see this sets the ignition at full advanced ...?? Now, what impact does this have on low speed running or starting? Is there any mileage in making up a plate to take the TPS sender and linking it to the Keihins? There's a blanking plate on the LHS of the LH carb where the actuating shaft passes through ... Am I making mountains out of molehills...?
G
