Fekkin Keihins...
Posted: Fri Jan 26, 2007 12:46 am
by Greg
Ok - so they're on, and now the engine has a pick-up like never before and the exhaust is really 'barky'...
Now, here's the list of new keihin owners questions!
1) Is there a user's manual anywhere - does anyone have a copy I can copy or borrow or scan??
2) in the absence of the above, I can't at first sight see how they are synchronised - any help or don't they need it?
3) Looking at the carbs from the top, there is a pair of joining tubes with spigots - the bottom is the fuel inlet (well at least I hope it is!) .. is the top one an overflow outlet??
4) Assuming that the bottom spigot is the fuel inlet, mine is pissing fuel out quite badly - are the carbs easily separated and are the seals easily replaced (now you see the relevance of the sync question eh?) but what I don't want to hear is that I've been filling the carbs via the overflow spigot #-o !
And... then there's the question of the TPS ... I've seen the wiring mod and as far as I can see this sets the ignition at full advanced ...?? Now, what impact does this have on low speed running or starting? Is there any mileage in making up a plate to take the TPS sender and linking it to the Keihins? There's a blanking plate on the LHS of the LH carb where the actuating shaft passes through ... Am I making mountains out of molehills...?
G
Posted: Fri Jan 26, 2007 6:41 pm
by dillthedog
hi greg i have some paper work with mine i will copy it at work monday then post it to you you will have to send me your address
a;
trouble shooting guide,
parts numbers, and a blow up,,
instructions
Posted: Fri Jan 26, 2007 10:06 pm
by bobtrx
Greg the top tube is the air vent to which I ran a tube to exit under the bike and bottom is fuel in , I did the wiring mod for no TPS and have no problems there , just sorting out the fine tuning of the carbs
Posted: Sat Jan 27, 2007 11:34 pm
by Kevtrx849
Hope this helps to clarify things.
Posted: Thu Feb 08, 2007 7:23 pm
by dillthedog
how you getting on greg
Posted: Thu Feb 08, 2007 11:11 pm
by Max
Dill, where did you get that picture of George Burns? :lol:
Posted: Thu Feb 08, 2007 11:30 pm
by Greg
Hi Dill...
I got kinda sidetracked....
Hope to get Trix back on track this week though!
G
