850 v 900 cylinder head differences?
ron850
Post by ron850 » Sat Jun 28, 2014 6:40 am
Apart from the mounts being cast on different positions on the head what are the other differences between an 850 and 900 head?
Bigger valves on 900/better porting etc?
I am aware the cams are different with 900 ones having a phase sensor
'97 Red/Black UK bike, R1 14b front end, Thunderace rear, zx10r shock, adjustable dogbones, std motor on TDMR40's, Ignitech prog ign, Gibson cans
TDM900 engine build imminent
Re: 850 v 900 cylinder head differences?
Post by sanddune51 » Sat Jun 28, 2014 10:08 am
The valves are definitely the same as the later revised Trx ones. Not certain of internal differences but I would expect the porting to be the same as the Trx and 850Tdm. I believe the external differences are well understood and documented on this forum.
Rod.s
Post by Rod.s » Sat Jun 28, 2014 10:53 am
sanddune51 wrote:The valves are definitely the same as the later revised Trx ones. Not certain of internal differences but I would expect the porting to be the same as the Trx and 850Tdm. I believe the external differences are well understood and documented on this forum.
The inlet ports are scolloped to allow for the injector spray pattern :D and the external casting is different…plus…..mmmmm
Post by Killerwhale » Sat Jun 28, 2014 7:39 pm
And the TRX enjun is a bitch to carry, whilst the 900 is much lighter. I´ve tried both :)
