Removing coils
dfh
Removing coils
Hi all.. I'm stripping the frame off the bike to get a crack in the subframe welded and all is going well except the Phillips head screws mounting the coils are tighter than a ducks date. Any ideas how to get them out?
- Con Rod
Re: Removing coils
WD 40, heat and patience. Get some stainless fasteners to replace what you take out and save yourself a future headache
dfh
Re: Removing coils
WD40 applied for days now... Heat seems inappropriate where coils are concerned & the brackets are too flimsy to use an impact driver.. Head scratching going on here.
- Con Rod
Re: Removing coils
well you could just drill of the heads. Worst case you have to tap a larger thread or use a nut an bolt
dfh
Re: Removing coils
Yes that seems like the next step.. Hopefully the coils are not threaded.
Ghunter
Re: Removing coils
I use side cutter pliers to gip the head of the screws and turn the screw when it's dug in nice and firm.
It's never let me down yet.
- devlin
Re: Removing coils
You could also use a hacksaw to cut a slot across it and see if one of your big flat screw drivers can get it to turn.
Re: Removing coils
Upgraded coils are pretty cheap now with a pair of dynatec DC-3's from the U.S. down to about $150 delivered.(and a simple swap) Timing , good spark and correct fuel/air keyster carb kit will give you so many gains and totally transform your TRX for under $500.
Rich
Re: Removing coils
drill the screw heads off, coils are not threaded, they will pull off. Don't bother with WD40 use diesel as s penetrating fluid.
dfh
Re: Removing coils
Thanks guys, will try drilling. Electrically the old beast is good so no wishes to spend on new coils. Cheers
