Petrol/match/strike/run,,,,,,,,,
Posted: Fri Jul 25, 2014 11:24 am
People, I need drink, drugs, therapy, a priest, whatever. Tried everything this dope can think of and still nowt.
Starts spot on, bit grumpy for a few seconds then idles sweet and responsive on throttle .
Set off, all good, lovely sweet quiet motor, feeling the love.
After exactly the same distance every time, no matter what I try she starts to cough, fart, puke and dies.
After 30 secs of cranking, boom, all is good.
Exactly the same distance later repeat, cough,,,
Valves done, carbs good, filter good, timing etc everything good.
I've changed, replaced, everything. Plugs, leads, petcock, cdi, coils, vacuum pump, all pipes, tank cap, starter solenoid, everything.
All terminals and connections are 100% clean, all earths are good.
Exhausts joints are good.
Latest thing I tried was doing away with the tank filter and fitting a clear inline one, no other filter fitted. When the bugger conked out, I could clearly see air bubbles. These went with continual cranking and she started. The tank cap seal was looking a little hard so I swapped it for a good one.
No joy, still the same.
Doooin me head in big time. Hellllllllppp meeeeeeeee
