TPS
SDN
TPS
Post by SDN » Sat Jul 26, 2014 7:02 am
My TPS is not adjusting, no matter how much I try it's either at 8K or 1K. Resistence was slightly out, new price is prohibitive and do not want to lose low down punch by doing TPS bypass. Does anyone know if TPS is common to other models, one forum suggested
Gary said :-
XJR 1300, GSX600F Katana Bauj. 2000, GSF 1200 Bandit, SV 650, DL 650, SACHS Roadster 650, R1 all the same
Does anyone know if this is right?
Re: TPS
Post by Con Rod » Sat Jul 26, 2014 7:27 am
XJR1300 is definitely correct, I got mine off one
Re: TPS
Post by cobbadiggabuddyblooo » Sat Jul 26, 2014 10:24 am
xj900s diversion from 97-02
xj1200 98
xj1300 98-2000 including the sp models
They all share the same part number and interchangable.
Try calibrating with the ignitec first.
Throttle position sensor TPS input.
An input is ready for standard TPS sensors used on motorbikes. It is designed for voltage range 0 - 5 V. Sensor
settings for 0 % and 100 % is set by TCIP4.EXE software.
Check it out in the manual when it arrives.. :wink:
It may save you unwanted costs for a replacement TPS
SDN
Re: TPS
Post by SDN » Sun Jul 27, 2014 7:19 am
OK cheers
Regards
Simon
Re: TPS
Post by cobbadiggabuddyblooo » Sun Jul 27, 2014 4:32 pm
Last edited by cobbadiggabuddyblooo on Mon Jul 28, 2014 11:18 am, edited 1 time in total.
steveng
Re: TPS
Post by steveng » Mon Jul 28, 2014 11:10 am
Don't know if this helps, but I had a similar problem with mine,just could,nt get it set on 4000,thought it was knackered,put a tester on it and it was ok,so I just gave a good
clean,bit of w/d on the block conector,now it's fine,worth a try
SDN
Re: TPS
Post by SDN » Fri Aug 01, 2014 1:03 pm
OK cheers will try a clean up! anything to save money
