Quick question guys. Can you change the clutch cover gasket without draining the oil first? I've got a weep from where a garage obviously failed to do the job properly.
It's just had an oil change so don't really want to do another 500 miles later.
Clutch cover gasket change
Re: Clutch cover gasket change
Yes, best to lay it on it's side or well over on the side stand. A slight loss of oil will happen but only a spoonful
Red Rex
What's wrong with draining the oil, fixing your gasket, and putting the same oil back in ??
Why do it the long way?Red Rex wrote:What's wrong with draining the oil, fixing your gasket, and putting the same oil back in ??
