Clutch cover gasket change
Dave C
Post by Dave C » Fri Aug 29, 2014 12:56 pm
Quick question guys. Can you change the clutch cover gasket without draining the oil first? I've got a weep from where a garage obviously failed to do the job properly.
It's just had an oil change so don't really want to do another 500 miles later.
Re: Clutch cover gasket change
Post by Con Rod » Sat Aug 30, 2014 1:26 am
yes, you might spill a little but with the bike on the side stand you will be fine to replace the gasket
Kobo1
Post by Kobo1 » Sat Aug 30, 2014 3:00 pm
What Con Rod said or lean it further over by resting the left handlebar on a bench top or even a wall. Just chock the front wheel so it can't roll. Have fun...
Kobo 8)
Competing is everything, winning is just a bonus.
When the flag drops, the bullshit stops....
Dave C
Post by Dave C » Sat Aug 30, 2014 6:06 pm
Thanks guys. The answer I was looking for.
Job for next weekend I think. Are there any things I should watch out for when replacing the cover?
Dave
Silver
Post by Silver » Sat Aug 30, 2014 6:45 pm
I think you need to remove the circlip on top of the actuator arm and remove the actuator arm otherwise you can't get the cover off, well i couldn't.
SDN
Post by SDN » Wed Sep 17, 2014 9:07 am
As silver says take the circlip and actuator arm off to get cover clear. I did mine on side stand when changing clutch with no oil coming out.
