High RPM issue
Posted: Thu Dec 04, 2014 5:31 pm
by Will de Beer
Hi Everyone i need help please, my trx seems to be loosing timing at about 5 -6000 rpm, bought the ike with the issue, then did new carbs kit, new timing chain and valve clearances, everthing is 100% but she still limits at high rpm, anyone got any ide on this issue??
Please i need help!!
Thanx
Re: High RPM issue
Posted: Fri Dec 05, 2014 6:59 am
Japanese imports employ a limiter at 180kph.
There as sensors in the speedo that trigger the limiter in the ECU under the riders seat.
Sensors are at 180kph and at 0kph so you can't just bypass it by disconnecting the speedo cable from the drive on the front wheel.
Re: High RPM issue
Posted: Fri Dec 05, 2014 11:26 am
by Will de Beer
Hi thanx there is no speedo on it but the speedo only runs a cable so more likely the rev counter(also not on the bike) should limit, the limiting is in every gear #-o it doesn't rev into the solid toque even
Re: High RPM issue
Posted: Fri Dec 05, 2014 4:54 pm
by Snod Blatter
The Japanese lmiter is at 7K RPM so not the issue. There are many things it could be though, a coil not working properly or float height nowhere near right. It's hard to gine anything but possible ideas, this is not a known issue.
Re: High RPM issue
Posted: Fri Dec 05, 2014 9:34 pm
by Stu99
Hi Will,
You don't give a lot of detail to go on but I would start by checking and ticking off all the boxes of both your electrical/ignition system and fuel delivery system.
What is happening at that point of rpm?
Will it just not rev harder but remain smoothish or
Does it chug or surge
Does it start to missfire
Does it backfire through the carbs
Does it do something else entirely?
Was this problem there before the carb kit, timing chain or valve clearances we done?
More info may get you some better answers from the collective. 8)
Re: High RPM issue
Posted: Sat Dec 06, 2014 7:33 am
by Will de Beer
Hi appreciate the help, carbs are 100% in spec, was done due to worn tubes, timing chain was done cause old one was stretched out. Can't tell exact rpm's cause rev counter was removed. I bought it not working already. It sounds exaclty like a limiter when it does that, sounds like spark is being cut, no backfire through carbs though, I'll try and get a sound clip so you can hear if it will help?
Re: High RPM issue
Posted: Sat Dec 06, 2014 11:48 am
by Snod Blatter
Does the CDI have an orange or a green sticker on it?
Re: High RPM issue
Posted: Sat Dec 06, 2014 7:27 pm
by Rich
check the alternator output
Re: High RPM issue
Posted: Sat Dec 06, 2014 11:04 pm
by Will de Beer
Hey thanx for all the help, no sticker on the CDI, What sould the reading be for the alternator output?
Re: High RPM issue
Posted: Tue Dec 09, 2014 2:41 pm
by misterdimwiddy
Usually 14-14.5V if the regulator is working.
Re: High RPM issue
Posted: Wed Dec 10, 2014 12:40 am
by QuickDraw
Also, have you checked plug gaps? Unset/incorrect gaps can do that too. We assume they would be correct but I've been caught out before.
Re: High RPM issue
Posted: Sat Jan 31, 2015 4:58 pm
by Will de Beer
Hi guys sorry long time, got it semi sorted, got the orange sticker ecu, it still limites at different rpm, any clue why. Got the bike with me so plz help
Re: High RPM issue
Posted: Sun Feb 01, 2015 4:48 am
by Rod.s
Pop the cam cover off and check the cam timing and valve clearance…..
Re: High RPM issue
Posted: Sun Feb 01, 2015 5:10 am
You have an import ECU and a limited ECU...
I've pulled the speedo apart and have a good understanding on this problem.
The speedo has a disc connected to the speedo needle axle.
There are magnets placed at 0KPH and at 180kph that trigger the limiter.
disconnect the speedo and you still have an issue.
You will find the Japanese import models also run a 17-41 gearing as std which raises the rpm so if yoiu are running the std 17/39 this will lower the revs to around where you are having the limiting issue.
RPM is a variable because gearing dictates this, the limiter is in place at 180kph and 0kph period... :wink:
See if you can borrow an ecu from a forum member close to you that is not a Japanese import or get aN Ignitech fully programable ignition to fix your limiting issue.
Re: High RPM issue
Posted: Fri May 15, 2015 8:49 pm
by Will de Beer
Hi guys thanx for all the help, got it sorted somewhat, new issues keep popping up, can't get this damn thing sorted!!!
