Clutch and crank removal.
Post by cobbadiggabuddyblooo » Sat Dec 06, 2014 12:36 am
Removing the crank once again from the motor and I'm wondering if I can leave the clutch basket on the gearbox shaft??
I know the rotor on the crank has to come off so I can access the balance shafts .
I will only need to remove the crank for balancing and then placing straight back in so I'm keen to know if this is possible or more to the point practible .
Re: Clutch and crank removal.
Post by misterdimwiddy » Tue Dec 09, 2014 2:33 pm
I have a feeling there may be a bearing retaining plate that spans the split line in the casings?
Not certain about this but could check leafing through the pdf manual?
Post by cobbadiggabuddyblooo » Wed Dec 10, 2014 3:42 am
Cheers Dimwitty,
Had the same thought yesterday and I think it is the j shaped retaining plate held by 3 bolts that holds the shift shaft and spring Inplace that rotates the drum in the gearbox.
