Cam followers
Cam followers
Kentcams has arrived...finally!
The cam followers should be changed when changing the cams, anyone has a link to a dealer in europe who don´t charge as the yamaha centers??
Also, is there any other things to think about??
Tourqe-a-holic
- Max
- Janitor
- Max
- Janitor
Shifty wrote:I think he means the nice shiny things on top of the shimms
I call them buckets. Cam followers to me are more like rocker arm thingies. Mine had no sign of wear at all when I rebuilt the engine before the 4hr (about 22K on the clock). Nice and shiny is the description. I wouldn't replace them unless they show scoring or uneven wear.
Yup, look like buckets!Max wrote:Shifty wrote:I think he means the nice shiny things on top of the shimms![]()
Hope they look as good as yours, i aim at keeping ´em!
Tourqe-a-holic
- Shifty
Normally I would say, new cams new buckets coz when you adjust the valves u stick the buckets in the same spot as were they came off.
So they are kinda related to the cam lobes and valves.
But maybe its all not that critical and you can use the old ones if they dont have any sign of wear.
Make sure you fit the buckets in their original place.
Greetzz
Greetzz
Thanks for that input!!Shifty wrote:Normally I would say, new cams new buckets coz when you adjust the valves u stick the buckets in the same spot as were they came off.
Greetzz
Tourqe-a-holic
- Max
- Janitor
I've Kent cams in my motor and the original buckets were used...............runs nice and quiet and to change to the clearances as yet...........
