Annoying, as with the reg/rec out the way it's only around 1.5mm away - wonder if I could grind that much off the top of the shock reservoir?
I thought I read the ZX6R shock fitted, but it must be an earlier model without the piggyback reservoirM.V. wrote:Most people use the R6 shock, were you trying something different or did you get the wrong shock?
Hi Cobba,cobbadiggabuddyblooo wrote:Excellent choice.
I set up a 900 hornet last years for Janets nephew with the same model wilbers shock and the difference was like night and day.
Adjustable ride height on the bottom as the photo is a little blurry???
