won't start when cold
Markula
Post by Markula » Fri Apr 17, 2015 8:29 pm
Hi All
Hope someone can help... Having just recommissioned my Trix after a year off of the road I am finding that she won't start on cold mornings? I put new plugs, filters, oil, battery, etc in as part of getting her back on the road and when the days are warmish she starts fine. But if the temperature is below about 6 degrees she just turns over endlessly without kicking into life? If I use a blow torch to warm up the front of the engine a bit she then starts up. Any suggestions on what to do are greatly appreciated.
Mark
drix
Re: won't start when cold
Post by drix » Fri Apr 17, 2015 8:33 pm
Have you checked valve clearance? What's the mileage?
Markula
Post by Markula » Fri Apr 17, 2015 8:53 pm
The mileage is just over 17000 and the valve clearences were set about 2000 miles ago so I was not thinking in that direction?
M.V.
Post by M.V. » Sat Apr 18, 2015 1:10 am
I hope you mean 6 degrees celcius :shock:
If so, yes, I would be checking the valve clearances first, sounds like they may have closed up or been done wrong.
Post by alextrx850 » Sat Apr 18, 2015 1:16 am
You haven't yet suggested using the choke mechanism yet...
Post by Killerwhale » Sat Apr 18, 2015 7:56 am
alextrx850 wrote:You haven't yet suggested using the choke mechanism yet...
Someone on here had a buggered choke mechanism IIRC
Markula
Post by Markula » Sat Apr 18, 2015 8:39 am
The choke needs to be used in the morning to get her started and it seems to work as it should (as far as I can say without stripping the mechanism).
SDN
Post by SDN » Wed Apr 22, 2015 3:00 pm
Try anything that will make it run weak - carb rubbers vacuum pipes etc.
Also check choke is comming on
If it has been laid up, was petrol drained as the carbs may be gummed up with old fuel, try stripping and blowing out carbs and jets empty old fuel out of tank and fill with fresh fuel
Post by dandywarhol » Wed Apr 22, 2015 11:25 pm
Just a thought - don't use any throttle when using the choke, or else the choke won't operate.
If it's warm enough on May 7th you could take a run out to the Leadburn Inn - there should be a fair gathering of bikes on the first Thursday of the month...............
Post by Con Rod » Thu Apr 23, 2015 12:52 am
it should need the choke to start when its cold. If it doesn't it is too rich. For some reason people consider it a fault when a bike wont start cold unless its on the choke. This is incorrect. This about it, why would you set up a bike to run well at 6 degrees when 5 minutes after you start it it is running at 70 degrees. You tune a bike with the engine heated up, and you have a choke to compensate for cold starts.
Markula
Post by Markula » Thu Apr 23, 2015 9:17 pm
Thanks for the support folks
It started fine tonight (Nice weather, 16 degree heat) and didn't miss a beat on a blast around the local area. I am going to try and find time over the weekend to pull the carbs off and clean out, inspect pipes, etc. I think I will also compression test the cylinders to see if there is any indication of a valve problem.
I would have loved a blast out to the leadburn inn dandywarhol, but sadly work commitments are going to take me elsewhere on the 7th :( . But possibly catch up the following month there?
Cheers again folks
Mark
Post by dandywarhol » Thu Apr 23, 2015 9:33 pm
Did it require choke at 16 deg. tonight? Mine did - just about half, then shut off within about 5 seconds
Markula
Post by Markula » Sat Apr 25, 2015 11:37 pm
After struggling to start tonight (cold) I pulled out the plugs... even though the engine must have turned over for about 1 minute and a half the plugs were still dry? Does that suggest gummed carb problems? I was going go do a compression test but just discovered my compression tester does not go down to a size Small enough to fit in the plug hole!
SDN
Post by SDN » Sat Apr 25, 2015 11:49 pm
Does suggest your not getting any fuel, if you didn't drain the fuel, the carbs might be full of crap - modern fuel is full of shit additives and petrol goes off! If you are getting a good spark as timing is fixed it really leaves fuel. Does it pop, bang and try to fire?
Markula
Post by Markula » Fri May 01, 2015 10:08 pm
Nope. Nothing like that. It either starts (Temp above 6 degree) or just continually turns over until the battery runs flat. I spoke to a trustworthy biker mechanic today who thinks it is more likely to be a vacuum pipe or old perished rubber link between the carbs and cylinders. His point was that if it was gumming up of the carbs the bike would run rough even after staring... which it doesn't! Once it is going it runs great!!
I have pulled the carbs off tonight and the carb to head rubbers are pretty badly perished ( as you would expect from a 19 year old machine) and have ordered up a replacement set, I will service the carbs and reinstate with the new rubbers, then let you all know how things are going.
Thanks again
Mark
