Been having a problem since the ported head and different barrels were fitted with the cooling system pressurising and losing coolant.
I put it possibly down to a pattern head gasket - Athena, not that cheap
When third gear went and I decided to tear it down early in the year I decided to go for a copper head gasket, courtesy of Brian (Cobba). I carefully checked the head gasket I removed, but could see no sign of it blowing, or any sign of the head being faulty????
So I rebuilt the engine and all seemed well, however the pressurisation problem did re-appear. I fitted a lower temp fan sensor, wondering if it was heat from the tuned engine overwhelming the cooling system. I also checked the stat and bingo it was opening late and not opening fully. I replaced the stat and rode the bike to work - unfortunately when I got off the motorway there was water pouring out of one of the little carb warming hoses - maybe it had partially loosened when fitting the stat??? I pulled over, re-fitted the hose and filled it with water, most of the water was gone. The bike started up after a good few chugs on the starter and I got it home.
Started it again - (more difficult to start) and noticed water pooling on the floor - it was coming from the exhaust - bugger - blown head gasket, or maybe the 2nd hand ported head was faulty???
Anyway taken the head off again - No sign of blowing on the head gasket??
No sign of anything wrong with the head???
Anyway I have cleaned, de-coked and re-seated all the valves on my original head and replaced the valve seals and I was going to bolt this head on in place of the ported 2nd hand one as all my problems started since the head was fitted.
However it has occurred to me that I also fitted some 2nd hand barrels I had that I had never run on the bike so were unknown quantity
See photo of discolouration between barrels on liner - its the only visible thing I can see
Re-fitting springs to old head after seating all valves
So question is head or barrels - I don't want to do the wrong thing here!!
anyway - does anyone have any suggestions as I don't think my marriage will survive another engine teardown + I want to ride the bloody thing not continuously work on it - feels like I have an old Brit bike - or maybe I should just bin it and buy a speed triple?
