TRX temp gauge calibration
yammyman
Post by yammyman » Tue Jun 09, 2015 12:06 pm
Hi guys, I recently replaced my black dials with a set of white units, Tacho and speedo no problem but when I took the temp gauge needle off I realised the stop is on the dial and now I am unsure as to accuracy, has anyone else done this and had this issue??.....if not then I would suggest you remove the screws then allow the needle to settle in its natural stop before marking the position and removing it.
Re: TRX temp gauge calibration
Post by cobbadiggabuddyblooo » Tue Jun 09, 2015 1:53 pm
Just run it till the thermo fan kicks in at 106*c
Notice the position and mark it when it kicks in and if need be remove the white sticker to reposition.
yammyman
Post by yammyman » Wed Jun 10, 2015 3:18 am
Thanks for that info, pretty much resigned to doing it that way.
