Seat pad
Posted: Mon Jun 15, 2015 3:45 pm
by bigstey
Hiya I am new to the forum, and its my first of many requesting information re my new TRX.
First question is, is there a supply of the small back support seat pad?
Ta Stephen
Re: Seat pad
Posted: Mon Jun 15, 2015 3:53 pm
by drix
Hi & welcome
Kedo in Germany sell some if not, have yours recovered (cost me £10).
Adrien
Re: Seat pad
Posted: Tue Jun 16, 2015 2:49 pm
by pbear62
Hi Stephen,
These rear pads are still available from Yamaha but are fairly pricey - mine was AUD $180.00 six years ago!
You can get them recovered but it depends on how original you want the bike to be.
Whereabouts are you located? (This forum has members from all over the world!)
Cheers, Andy
Re: Seat pad
Posted: Tue Jun 16, 2015 9:25 pm
by dandywarhol
I got a spurious one recently from the forum here - it looks great but it's a bit bigger than the original, so if you're a fat bastard it might not work.
Also curiously, the different size causes turbulence and a draught around the kidneys :shock:
Re: Seat pad
Posted: Wed Jun 24, 2015 10:20 pm
by bigstey
Thanks for replies
I am in the north of England
And I have seen the larger ones but I am not that keen on them.
I have been wondering if it could be sprayed with some sort of plastic paint
Re: Seat pad
Posted: Thu Jun 25, 2015 6:43 am
by Wombat
Black Plasti -Dip might do it
Re: Seat pad
Posted: Thu Jun 25, 2015 8:13 am
by Con Rod
I really dont think plasti dip or any kind of paint is going to work. Simplest thing to do is get some leatherette from an upholsterer, its so small an off cut would do and just re-cover it. Assuming you have a staple gun it shouldn't cost more that a couple of quid
Failing that an upholster would probably do it on the spot for not much money
Re: Seat pad
Posted: Sun Jul 05, 2015 8:36 pm
by bigstey
Plastic dip looks a good option, or I have found a new one on eBay £70 plus postage, has anybody removed it and fitted two grommets in the holes, it may be a solution
Re: Seat pad
Posted: Mon Aug 31, 2015 11:25 am
by slow codger
:shock: think I've got one somewhere in the garage along with the seats, will have a look when I get 5 minutes.
Re: Seat pad
Posted: Mon Aug 31, 2015 11:43 am
by goose202
I used some thin self adhesive foam cut to shape.
Was cheap from the local rubber and plastics shop.
Re: Seat pad
Posted: Mon Aug 31, 2015 10:01 pm
by Rich
I think it's a steel plate with the foam stuck to it so difficult to staple to.
