Braided brake lines
KJP11
Braided brake lines
Post by KJP11 » Tue Aug 18, 2015 6:52 am
I have a 95 import with the Brembo brake calipers. Want to replace brake lines with braided, does anyone know if standard ones that fit Yamaha calipers will fit?
Re: Braided brake lines
Post by Mincehead » Thu Aug 20, 2015 7:42 am
Should do, might be an issue with the banjo angle but if you buy a`build a line` kit from Goodrich or better still my favourite company Venhill`s you can adjust the angle anyway:
http://goodridge.brakes-hoses-fittings. ... daline.php
http://www.venhill.co.uk/
Post by fung » Mon Sep 21, 2015 2:19 pm
Sumitomo and brembo calipers are different length lines.
brembo are shorter lines as the banjo is further up the brake calipers.
The ends do have a different angle too.
