USB charging gizmos
Posted: Mon Nov 16, 2015 3:19 am
by wreckage
What I know about electricity could be written on the back of a stamp and I want to buy something similar to of these:
http://tinyurl.com/o3utmyc
http://tinyurl.com/opxw62w
Are they supposed to be wired directly to the battery? Is there anything else I should be aware of?
Cheers.
Re: USB charging gizmos
Posted: Mon Nov 16, 2015 4:05 am
by alextrx850
Straight to the battery , the second link is the better ,..as it has the positive and earth already in place with the fuse receiver in the line.
Posted: Mon Nov 16, 2015 4:12 am
by dicky
Normally straight to the battery, but if the socket end has an internal LED like the first link seems to, then you'd be best to have an on/off switch in there as well.
Posted: Sat Nov 21, 2015 1:47 pm
by jjmoto
Not sure whats available in Oz, but a mate got one from The Adventure Bike shop in the UK which has an integral on/off switch. I am also not clever with electrical stuff so when i wired in my father in laws sat nav to my wifes bike the usb port is permanently lit up. I just resorted to removing the fuse when not in use so it didn't drain the battery.
Posted: Sat Nov 21, 2015 10:57 pm
by wreckage
jjmoto wrote: I just resorted to removing the fuse when not in use so it didn't drain the battery.
As good a solution as any. =D> :)
I ended up ordering the item in the second link so I'll let you know if after I've wired it up the horn sounds when I indicate... :D
Posted: Mon Dec 21, 2015 11:26 am
by wreckage
I fitted a unit identical to this one yesterday but in black. When I checked eBay these shiny ones weren't available:
http://tinyurl.com/hj4j4lh
I picked it for three reasons...
a) I'm lazy
b) it has an on/off switch
c) it has an in-line fuse
Positioning it wasn't that difficult either. I have an Oxford tank bag which has a waterproof hole in the front so a charging cable can be poked through to connect to either a 'phone or a satnav device which can sit under a clear cover at the top of the bag.
I thought about a few different locations but ended up just screwing the clamp that the unit ships with, minus the spacers, onto a frame strut. I had to use a bit of rubber from a roll of adhesive rubber weather-proofing to make it fit and a couple of zip-ties for the cabling, and Bob's your auntie's lover.
