Got another problem
Steelback
Got another problem
Post by Steelback » Fri Feb 23, 2007 8:00 pm
:( Temp gauge is not working - how do you check it out :?: :?:
Red Rex
Post by Red Rex » Fri Feb 23, 2007 8:24 pm
You sure? It has to get bloody hot here in the UK before it needs to work. If you need to wear anything thicker than a tee shirt under your leathers then it's not hot enough for the temperature gauge to register ... if it does you more than likely have a problem.
Steelback
Post by Steelback » Fri Feb 23, 2007 8:35 pm
Would thought it would move a bit tho - needle does'nt even twitch :?
Post by trixynut » Fri Feb 23, 2007 10:58 pm
from memory, it's just a screw-in sensor in the radiator pipe inlet: trace the wires back from the gague. If you can unscrew it (may need to lift the tank) and then heat the sensor you've taken out (in your hand or gently with a lighter/hairdryer) it should show if it moves. Don't run the engine with the sensor plug unscrewed or it will pump out coolant.
steve speed
Post by steve speed » Fri Feb 23, 2007 11:29 pm
if you earth the wire from the sender for a split second the gauge should move up but dont do it for to long as you risk damage to the gauge (do this with the ignition on) check wiring and then the sender ,,down load the Manuel from downloads ,,i went out on mine today over to Blackburn and the gauge never went higher than 65deg ...hope this helps !
Steelback
Post by Steelback » Fri Feb 23, 2007 11:31 pm
:) thanks guys
