Morning all
Can anyone provide the following info please to assist with my TR1 build. I have the YZF front end bolted on (easy stem swap between bottom yokes and used original bearings; one YZF and one from TR1) and am gradually sorting the spacing and chain alignment for an FZS600 5" rear rim but the original spindle is no good.
I need the following if you can help?
Confirmation that TRX rear wheel spindle is 20mm OD
Full parallel length of 20mm OD section of TRX rear spindle
Post of High quality photo of Haynes manual wiring diagram for LH switch gear; I am changing switch gear on the TR1 and the light on/off control has to swap from the RH to the LH side. Am amazed that lots of the loom colours between 1981 TR1 and 1997 YZF correlate so its not that much of a job but LHS is less clear.
Also any recommendations for fabrication of custom headers; I need a full system but have yet to decide on twin/single cans as well as overall style.
Many thanks in advance.
Phil
TRX information needed
- Stu99
Re: TRX information needed
Pic attached.
- Stu99
And
Thanks to you both; that is exactly what I needed
